96" with 222 cam advice
I just got done Searching for the last hour and all I could find is 103" with the Wood 222 cam..
I caled FM up today and Jamie said the 222 would be the best for what I'm looking for, more passing power. All the dyno charts he has are 103". I know there isn't a big difference from the 96" to the 103" but I would love to hear from any one with a stock 96" motor and stage-1 with the 222 cam.
Only other cam I'm interested in is the SE 204. My Indy dosen't care what cam I get but he likes the 204 and 222 and 48H.
I prefer to buy from FM for there great after the sale service.
I have a trouble free 11 stock 96" with 19000 miles and Bassoni megaphone slip ons with stock head pipe NO cat and FM air kit and a PCV from FM. I ride solo only 190 lbs.
From Fuel Motos web page, scroll down to first dyno sheet. 96" with 222 cams:
http://www.fuelmotousa.com/site/performance-cams.html
Just a bit surprised that he is showing 6th gear runs, they give bigger numbers then a 5th gear run. I've had 3 dyno runs by 3 different tuners over the last 4 years and all of them show 5th gear in SAE. I have been told by others that 5th is the standard.
Has any one had a 96" with the 222 done in 5th gear? that's the only way that I know how to compare the numbers.
I have a 2008 Road King and I have been running Rinehart True Duals with a Big Sucker A/C. and a Power Commander III. I just added the 222 cams based on all the Dyno #'s I have been reading. I also added a Power Vision. I got a base map from Fuel Moto and I put my o2 sensors back in then ran Auto Tune. WOW what a ride. I love it in every gear and while cruising. Gas milage is at 39 mpg 2 up.
crzoomb (05-31-2021)
You can take away about 2 & 2 I believe on a 6 gear run and that puts you right at 204 numbers. The 222 has the same intake closing as the 204 and that's not by coincidence imo.
