Need a new Battery?
Need a new Battery?
Hi All, I just wanted to share this with all of you. I had to change the factory battery on my 08 ultra this week. So naturally I called My local HD and they wanted 179.00 plus tax.( not installed) for a DEKA ETX-30L made by East Penn Manufacturing. I found a similar product online at Batterymart.com Big Crank ETX30L so I dropped them an email to ask the manufacturer. here is a copy of the email:
East Penn Mfg.
Lyon Station PA
www.dekabatteries.com
mark
Battery Mart
1 Battery Drive
Winchester VA 22601
800-405-2121
Fax 540-665-9623
Email: info@batterymart.com
Website: http://www.BatteryMart.com
Sent: Monday, May 20, 2013 10:04 PM
To: info@batterymart.com
Subject: Battery info
Hi can you tell me the manufacturer of this battery?
Big Crank ETX30L Battery
Part #:
ETX-30L
Thanks Bill
So with that being said its the exact same battery that HD sells for 179.00 + tax for $99.00 delivered..
Two days later at my front door and saved over 80 bucks..........
East Penn Mfg.
Lyon Station PA
mark
Battery Mart
1 Battery Drive
Winchester VA 22601
800-405-2121
Fax 540-665-9623
Part #:
ETX-30L
Thanks Bill
Got this from the Dyna section.
Got to Advance Auto and use this code TRT41 with this battery
http://shop.advanceautoparts.com/web...wer_16940019-p
Should work out to about $106 and if you return your old battery it's $96.
Model i have is their expensive model:
Model: BatteryMINDer 12248
Volts: 12V
Temp. Compensation: Yes
Amps: 2A / 4A / 8A
Power Source: 120 VAC, 50-60 Hz
Temperature compensated multi-stage 12v battery charger/maintainer/desulfator with precision settings for Gel/Flooded/AGM batteries and selectable amperage.
Volts: 12V
Amps: 2A / 4A / 8A
