Check Engine Light Doing Something New?
Old 05-27-2013, 06:04 PM
XMA's Avatar
XMA
XMA is offline
Default Check Engine Light Doing Something New?
09 FLHX
Turn ignition on like and wait for check engine light to go out before start as usual.
Now check engine light do something it has not done before (1 of the 2 happens).
1. Turn ignition on and wait for check engine light to go out, however, if I don't hit to start right away (withing 10 sec) light comes back on and then goes out again.
2. Turn ignition on and wait for check engine light to go out and start before light comes back on. If I do this the check engine light will still come back on for a few seconds and goes back out and stays out.
Either way light does not say on steady.
Other than that bike runs like it always has.
Anyone else seen this? Anything to worry about?
Old 05-27-2013, 06:16 PM
Def Mute's Avatar
Def Mute
Def Mute is offline
That is to let you know there was a problem at one time...
Might still be a problem, but that is telling you it is holding an historical code in memory.
After 50 start/stop cycles it should no longer do that, unless it is still a problem.
Old 05-27-2013, 07:54 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Mute is correct. Your ECM has thrown some codes in the past. You can see what the codes are, address and clear them, and if all is good, the behavior of the engine light should go back to normal.
Kyle C Kirk
11-09-2015 02:13 PM
G wizz
07-29-2011 05:05 PM
chizman
05-15-2011 04:35 PM
jrspringer06
10-26-2008 06:08 PM
20NightTrain03
07-06-2006 12:00 AM
Quick Reply: Check Engine Light Doing Something New?
