Metzeler 888
Old 07-25-2013, 12:19 AM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
Originally Posted by tnbillybob
I contacted Metzler, they recommended 44 rear, 40 front. Just over 1000 miles so far, like'em, especially in the twisties. Any tire would have felt superior to the American Elites I was running since they had over 19k on them and were cupped badly. Time will tell!
After I read this I put 44 in my 888 rear. But then contacted Metzler and they replied with the following.
Please note one should always inflate tires to the correct tire pressure as indicated in the owner’s manual. However Metzeler has found the air pressure suggestions listed below or in our brochure will improve mileage and customer satisfaction. Check cold inflation pressure frequently. Correct tire pressure is crucial for safe handling. Over inflation may impair ride comfort and reduce the contact patch between the tire and the driving surface of the tires. Insufficient air pressure will result in poor handling and cause a tendency for the motorcycle to "wander". In addition, improper and insufficient tire pressure will cause accelerated tire wear, increased fuel consumption, less control and the possibilities for tire failure due to an overloaded/under inflated operating situation.
RECOMMENDED MOTORCYCLE TIRE PRESSURES BASED ON LOAD
Front Solo 2 up Riding 2 w/load
36 38-40 40
Rear Solo 2 up Riding 2 w/load
38-40 40 40
We always suggest that running higher pressures (up to the max as stated on the sidewall) will increase the life of the tire with no adverse effects. Thanks for the question and have a great day.
Old 07-25-2013, 09:22 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
I just put these 888s on last month based strictly on my experience with the with the 880s for several years previously. Rode 2000+ miles in the smokeys at 40 and 40 2 up and tires are great.. got caught in a lot of rain and a couple of torrential downpours and tires were awesome.
One thing I did notice though when leaning into a curve (right or left) is the tread pattern on the sides of the tires make a funny noise when contacting the road...
all in all, love the tires and I always go by manufacturer recommended pressures on tires, not HD specs. Even Dunlop tells you to put more air in them than the HD manual states
Old 07-25-2013, 09:43 AM
stupid_rope's Avatar
stupid_rope
stupid_rope is offline
36 38-40 40
38-40 40 40
that's some good information straight from the horse's mouth
Old 07-25-2013, 10:28 AM
U-234's Avatar
U-234
U-234 is offline
Ironhead3fan, your '03 has weak fork springs from the factory. Race Tech or Progressive will help prevent your bottoming out problem. I went with Race Tech 85 lb springs and their Gold Valves. More than recommended oil or heavier weight oil will give you a rougher or firmer ride.
Old 07-25-2013, 10:53 AM
Echo Delta's Avatar
Echo Delta
Echo Delta is offline
Thanks UltraNutZ! Living here in the great NorthWet (Oregon) knowing how a new tire performs in heavy rain is a crucial piece of information.
Ed
Old 07-25-2013, 08:32 PM
tnbillybob's Avatar
tnbillybob
tnbillybob is offline
Red face Air Pressure for 2011 Ultra Limited and Other FLHCU's
I read Mike's post, #21 with great interest. I also read Checker's post (#14) and he has hit the nail on the head. I neglected to state that my bike was a 2011 Ultra Classic Limited, and this has created a potential problem because the load rating and pressure is different for many of our bikes. I WAS CORRECT IN THE STATEMENT FOR MY TIRES, which are 130/80B17TL 65H (Min 36, Max 42)and 180/65B16 ReinfTL 81H Rear (Min 44, Max 50). So to OVERINFLATE WOULD BE PUTTING MORE THAN 42 lbs IN THE FRONT AND MORE THAN 50 LBS IN THE REAR. Interestingly, the 99 to 03 model FLHCU is load rated at 74 H vs 81H on the 10-13 model, and the air pressure recommended in 36 min 40 max front, and 38 min, 40 max rear. The 04 to 08 (flhcu) tires, once again a different size, have a 77H rating, vs the 74H on 99-03, and 81H on 09-13, and the pressures for the 04-08flhcu are 36/40, and 38/40. All of this info is taken directly from the Metzler tire and fitment brochure, which I requested and received from Metzler.com. All Harleys are listed, and as you can see, tire sizes, ratings, and pressures are different depending upon YOUR bike. Now that all this is as clear as muddy water, I don't know how to get the PDF file that Metzler sent me on this forum, but it is available to all from Metzler. Thanks again to Mike and Checker's for arousing my curiosity and apologies for not stating the year and model of my bike when posting the pressures I used.
Old 07-28-2013, 05:52 AM
houronron's Avatar
houronron
houronron is offline
[QUOTE=UltraNutZ;11563652]I just put these 888s on last month
UltraNutz,
Were you able to find the 888s local or did you have to mail order?
Ronnie
Old 07-28-2013, 06:13 AM
UltraNutZ's Avatar
UltraNutZ
[quote=houronron;11574389]
UltraNutz,
Ronnie
houronron.. to be quite honest I really didn't look locally because everyone around here seems to want full retail for motorcycle tires. I always get my tires from motorcycle superstore. if you do find their prices are higher than someone else, all you have to do is call them and they'll match. Never pay shipping and every time I've ordered (many times) the tires were sitting on my doorstep within 3 days and my boys over at Mancuso never have a problem putting them on.
Old 07-28-2013, 06:42 AM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
Originally Posted by Shakeydeal
If I got 19K miles out of ANY set of tires, I would be pretty damned happy.
Shakey
me to
Old 07-28-2013, 06:54 AM
UltraNutZ's Avatar
UltraNutZ
I can do that easily with a front tire but never had a rear tire, whether dunlop, metzler, michelin, or avon make it over 12k or so...
Quick Reply: Metzeler 888
