HD LED Headlight Operation
I just bought a HD LED headlight for my FLHX. When the low beams are on the top light is on. When the high beams are on only the bottom light is on. The lights on the sides of the two main lights are on all the time.
The light I took out was a two bulb halogen light and on High beam both bulbs were on. How is the HD LED light supposed to work.
I bought the Truck Lite for my flht. I was interested in seeing which did the best job. Where did you get the light aiming instructions for the Truck Lite, they came with the HD light.
I had the same problem with my 2015 road glide and it comes with the led head light. I took the bike to the dealer after talking to them on the phone and them telling me they couldn't do anything for me. If you had your light installed at the dealer they changed your setting in the body control module and if not you should had both on when your high beams are on. Get them to change it back and you will have both low and high beams when your on high beams. There is a big difference. The setting in the BCM now for my bike is standard and halogen and I have both low and high beams on when on high beams. Now you light will be worth the money you paid for it.
I had the same problem with my 2015 road glide and it comes with the led head light. I told the bike to the dealer after talking to them on the phone and them telling me they couldn't do anything for me. If you had your light installed at the dealer they changed your setting in the body control module and if not you should had both on when your high beams are on. Get them to change it back and you will have both low and high beams when your on high beams. There is a big difference. The setting in the BCM now for my bike is standard and halogen and I have both low and high beams on when on high beams. Now you light will be worth the money you paid for it.
I have the reflector. It does not matter which lite you have. If you have a non LED lite that you have both beams on when on high beams and change it yourself you will get both beams on when on high beams. If the dealer changes it and changes the BCM to LED you will only have your high beam on when on high beam and only low beam on when on low beam.
