Question on Removing outer fairing on Ultra Classic.
First question: Are you just trying to disconnect the headlight, or do you want to remove your fairing?
Just a heads up: If you want to remove your headlight, it's easier to use a phillips screwdriver and just remove the headlight:
1 phillips screw for the trim ring
3 phillips screws to remove the headlight.
It's then very easy to unplug the headlight.
Received 47,744 Likes
You don't need to remove the headlight to remove the fairing ... but remember that you must squeeze ( on the sides ) the plug before pulling to get it disconnected.
Put socks on passing lights, unbolt outer fairing, wiggle it out some, just enough room to reach your hand inside and unplug the light. Comes right off. Cwick, nope, the bulb goes into the plastic housing, you cant remove the lens only. If its dirty/foggy, you can remove the plastic assembly, put a few drops of dawn diswashing detergent in there with a little water, swish it around, and let it air dry, or blow dry, should be good as new. You can also do the same with the passing lamps. DO NOT touch the glass on the bulbs, it will cause em to blow.
As said above, cover the passing lamps with socks or some type of rag. Make sure that you hold onto the innermost screws in the fairing near the forks when you remove them. They tend to fall off the driver and the disappear into the abyss between the forks. They aren't expensive to replace but they do make a little racket till they fall out. Oh, and don't be surprised if you see a few hickory nuts or some other kind of nut fall out when you take the fairing off. The parts manager told me that when I got some parts for under the fairing and I told him that my ride has always been garaged and there were no critters in the building. If the nuts had been rouund, I would have had enough to play pool.
