Passing lights adjustment
For reasons I don't understand, one of my passing lamps is too high. There's a section in the manual that goes into detail about where it should point, but doesn't say how to adjust it. There's no adjustment screws, just the lamp held in place by the retaining ring. Any ideas?
this should help, but be ready for a PITA job
https://www.hdforums.com/forum/elect...rn-signal.html
https://www.hdforums.com/forum/touri...ad-lights.html
Far as I know Snap On is the only company that makes one. I've checked with MAC and others and the don't. If you want the Snap-On I can tell you Its very expensive. Somewhere in the $50 area.
This is what I made using a cheap 9/16 deep well socket and a dremel tool. (this is not my exact socket, just a pic I pulled of the net.)
Its a cheap alternative and I works well. HOWEVER, do be very careful when adjusting the passing lamps as if you turn to far you will pinch the wire coming though the flarenut and loose your passing lights all together, and possibly all your lighting if its shorting out. Ask me how I know....its a real PITA to fix also.
Received 47,786 Likes
http://www.homedepot.com/p/Husky-8-P...1#.Udwb0xbXX0A
I have two of them. Husky makes them (Home Depot) and General Tools also makes one which can be found in most home improvement stores. I keep one in my tool box and one in the bike. You can use any bit in it and if fits in tight spots. Prefect for this application...(Bonus info- If you have the Brukus Saddle bag secure kit, this makes taking them on and off a snap!)
