Drive belt squeaks.
Old 07-12-2013, 08:45 PM
zeus33's Avatar
zeus33
zeus33 is offline
Big Kahuna HDF Member
Default Drive belt squeaks.
I noticed a new noise lately, so put it up on the jack and found out that its the drive belt making a squeak. Sort of a sound that rubber makes when slipping. The belt seems tight, none of the parts back there seem like their worn, cant feel any play in the wheel bearing.
What do you think it is? Should I tighten the belt some more or maybe it's just dirty? I'm kinda stumped.
Old 07-12-2013, 09:43 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
Put some poly lube on the belt.
Old 07-12-2013, 10:15 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
Just a slight dab will do it.
http://www.harley-davidson.com/store/poly-oil
Old 07-12-2013, 10:28 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
up on the jack, you can't check the tension.
a too loose belt may "zing" on decel ( and this is more likely with a lowered bike), it is the outside of the belt contacting the primary.
stay dry
mike
Old 07-13-2013, 12:45 AM
zeus33's Avatar
zeus33
zeus33 is offline
I don't have any poly lube. Will a bar of soap work? We used to do that with squeaky fan belts on cars back in the day.
Old 07-13-2013, 04:03 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
Belt dressing...
Sold in just about every auto parts store.
Old 07-13-2013, 04:52 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,547 Likes on 3,057 Posts
My belt lased 119,000 miles and looked good 'til the day it broke ( a cracked swingarm got it.) For the last 30,000 miles or so it squeaked on occasion though. I didn't have any belt dressing so I dabbed a little anti-seize on the outer edge (just the left side,) every couple of thousand miles and that stopped it.
Old 07-13-2013, 05:16 AM
tbone108's Avatar
tbone108
tbone108 is offline
If you use the soap, be sure to put it back on the sink but don't tell the wife lol.
tb
TEEBAR
04-26-2013 06:21 PM
Remnighttrain
09-29-2009 06:25 AM
panshovel4life
02-01-2008 03:35 PM
hdfxwg85
05-20-2007 05:07 AM
LOUD LARRY
05-10-2007 09:18 PM
Quick Reply: Drive belt squeaks.
