Help. Blinkers and horn not working
What did you use to check the fuses? Check the fuse again...I would say it is a bad fuse and not a relay. I had the same issue one time before...Just looking at the fuse it "seemed" OK...It wasn't until I used a multi-meter and tested the fuse that I actually found out that indeed the fuse was bad.
Ditto on the fuse,i've had similar problems with believing the fuse was good till I finally put a multi meter on it.After all that I replaced all my fuses with those new smart fuses that when blown for whatever reason a small led lights up on the edge of the fusewas for easy identification.
