Passing lamp mounted turn signals
Ok so after a week of searching and what not I still can't figure out how to wire my passing lamp kit, mounted TS's to the bike. I have went to 2 different HD dealers with no kinda help. They couldn't even give me the right parts I needed. But anyway
I have the passing lamps wired but I'm at a complete loss for how the turn signals are to be wired. I just want to get rid of the handle bar mounted on. Any help would be great. I also bought the HD wiring harness so the passing lamp will stay on with the brights but I didn't have any of the plugs the instructions said I should have
The bike is an 2005. I'll check tomorrow to see how many wires the factory turns are. Also the HD wiring harness I got today is part # 69200442. So it will allow the aux light to be switched on with either the high or low beams
Ok figured it out. Went to work and got some deutz connectors and wired the passing lights. Then took another look in the headlight housing and found where the T/S's connect to the main harness. Reprinted the connector I got from HD and boom everything works with connectors. Also installed the HD cig lighter plug along with some handlebar style speakers.
1960lespaul
04-13-2012 08:37 AM
lowrider610
Electrical/Lighting/Alarm
04-25-2010 11:24 AM
