Power Commander V v. Fuel Pak
Howdy! I'm debating the merits of the Power Commander V v. a Vance & Hines Tour Pak for a planned upgrade on a 96" 2010 Street Glide (exhaust and hi-flow filter only). I've had a Power Commander on other bikes in the past and have been happy with them.
Can anyone offer any input on the Fuel Pak?? Thanks!
-Carl
-Carl
Not a mind twister to program the FP. There are a lot of settings input based on your current settings. I found it easy to have someone read the settings to you while you input the figures. Again, I have never had a problem with the FP and V&H tech guys are very helpful if you give them a call. Good luck!
What I did was to install V&H monster ovals and V&H True headers and the VH FP. Additionally, installed a Mo Flo air cleaner. Never did the Stage One download. My bike runs fine and mileage ranges in the 38/40 mpg range. For my purpose, the FP has done what it is advertised to do. Obviously there are more sophisticated systems out there and the prices are reflective of that. For me, I just kept it simple and it has worked for me. As we all know, you can spend and spend on different systems. The FP is a simple system not intended to be a cure all but serves a limited fuel management system at a reasonable price.
The FP worked fine on my "10" SG with just a slip-on,Stock 2-1 header and SEstg1download,K&N filter. But I had no idea what my AFR was at or any other settings.They are very helpful at tech support but can't or won't tell you what each node's settings actually do. It didn't work so well when I upgaded to the S&S PTD's w/ V&H turndowns after many calls. So I went with the Power Vision.
Exactly, from what I understand there's no easy way to manipulate timing on the FP. Here's why that' s important: if down the road your bike starts to ping the only way I found is to retard the timing 1 degree at a time in the areas of the ping until it's completely gone. You can do it from any laptop at anytime instead of depending on someone else to do it........The PCV is the minimal tuner I would go with that will get the job done, but there are others that run much more depending on what you need them to do.
