Looking for a used Road King - What years to be cautious of???
The following is why I shopped for an '07....
Cable operated throttle
96" motor (1st year upgraded cam chest)
6 spd tranny
5 gallon tank (much better looking)
Brembo brake refitable
IDS refitable
All reasons I believe the best pre-'09 touring year
Reasons I own one....Great year!!
6 spd tranny
IDS refitable
http://www.jpcycles.com/tech/article...rive_System.pd
Can you change the rear pads without removing the tire?
Once I replaced all the cam bearings, cam tensioner and the cam with the upgrade, my '99 has been a no-hassle strong running bike. Love it!
I wouldn't hesitate to get a '99-'02 carb RK at all. Those years have the good lower end on the motors. You just have to fix all the stuff I mentioned above.
It is also going to get you the closest thing to a "potato potato" sound you can get with a Twin Cam. My friends are very jeleous of that part.
6 spd tranny
IDS refitable
6 spd tranny
IDS refitable
I opted for an '07 FLHP to get the 103 cu in and oil cooler. Makes for a great low buck starting point to modify.
I had a 04 Road King Custom and it was a nice riding and running bike.
Good luck with the search and glad your jumping back into a HD
Man I wish I had an extra 10k as I just found a 2009 for that price:
http://sanantonio.craigslist.org/mcy/3947116611.html
Beautiful bike and good price. I would just rather get something with low miles as I put 10-12k a year myself.
If its not in your budget to stay 09 and newer for the benefits of the new frame, 103, ABS ect then 04 and 05 are good years for a solid bike but keep in mind that you will probably need to do cam tensioners, a good way to go is the SE Hyd Kit and at the same time add a cam swap to wake up that 88, if possible add 95 kit and your good to go with solid power = to the newer 103s in stage 1 form.
