Fuel pump time?
Old 08-02-2013, 08:59 PM
xpilot's Avatar
xpilot
xpilot is offline
Default Fuel pump time?
I have a 2003 FLHTCI. Mods should make no difference for this question. There has been an occasional noise that almost sounds like a vacuum leak. It's the fuel pump I think. Is it normal, when I have the fuel cap off, to see fuel circulating in the tank when the fuel pump pressurizes? Or do I need a fuel pump, and/or repair leaky hoses?
Thanks for the responses
Old 08-02-2013, 09:17 PM
bagman1's Avatar
bagman1
bagman1 is offline
If you hear noise and see fuel swirling when the pumps pressurized, that is a sign that you have a hole in your fuel line (I have heard of this happening to quite a few people). Most likely you will only have to replace the line. If so while youre in there I would replace the fuel filter unless you just recently changed it.
Old 08-02-2013, 10:52 PM
Bill03E's Avatar
Bill03E
Bill03E is offline
Yep fuel lines rub the inside of the tank, and get pin holes, the replacements are shorter so they don't rub the tank. The replacements are also $150.00
Old 08-03-2013, 08:12 AM
xpilot's Avatar
xpilot
xpilot is offline
Its all jut more time and more money right?
blknslvr
05-16-2021 11:25 AM
Whiskyjock
06-07-2014 05:24 PM
gant
05-24-2013 07:41 AM
o3softtail
06-23-2009 12:57 PM
rip
11-28-2008 09:51 PM
Quick Reply: Fuel pump time?
