adjustable pushrods with woods lifters
Welp just adjusted my fm adjustable pushrods 28 flats or to .145. Hope it's not too much but after a couple hundred miles on the new lifters adjusted to .135 it seemed I was getting quite a bit of tapping from my tappets. One seemed a little tight after the adjustment but still spunin its cups. I suppose if it didn't that wild have told me it was too tight.
I am having a hard time understanding this thread.
If for example the lifters have .200 inches of hydraulic travel, and one adjusts the pushrods to compress them .145 inches, there is still .055 inches of hydraulic travel left within the lifter to allow for thermal expansion of components and wear.
As long as they are not bottomed out or >.200, or too loose such that the pushrod is not taking up all the slack, how can making small adjustments make any difference to the noise or performance of the motor?
Am I missing something?
Please explain.
Please explain.
Please explain.
Please explain.
Did you see my thread on adjusting FM push rods? Mine were a bitch to adjust - well I should say the hardest part was getting the intake tubes up enough to get the support chuck in.
https://www.hdforums.com/forum/touri...-pushrods.html
