Should I have gone further?
I pulled the outer primary cover off yesterday to investigate a knocking noise that I thought could be a loose compensator nut. The nut appeared to be tight and I tried to wiggle the rotor cover but no movement was there and the chain was to specs.
The noise is still there - is it possible the comp nut felt tight but maybe its not to torque specs? Should I have loosened it and re-torqued it? Or, is it likely if it felt tight and no wiggle then it is fine?
Ok Thanks - I don't have the slop in the drivetrain so I'm probably good. As suggested by someone, I am gonna get my hands on a stethoscope and try to pinpoint this noise.
Traceman
03-26-2011 07:09 PM
SkidderCycles
09-26-2009 12:18 AM
