Jiffy Stand leg stop question
When my bike is on the jiffy stand, the stand in angled slightly to the rear.
I don't have a means of posting a picture, so I'll try to explain that.
When I put the stand down, it is perpendicular to the bike. If the bike wants to roll forward, it can a little bit so the stand ends up pointing towards the back of the bike. It's never gone down, (except the first time I lowered it off my newly purchased jack) but it is a bit disconcerting
I've started parking while in gear (I used to always be in neutral) to get around this.
My question is:
- Has anyone found a way to modify the jiffy stand stop so the stand goes a bit more forward?
Thanks
My question is:
Thanks
I've thought and wondered the same thing but have just learned to live with it. The only thing I can see to do is remove the locking plate on top of the stand (while the bike is on the jack of course), weld a small buildup on the front edge and grind away a bit of the back side so that it will rotate the stand slightly more forwards.
Not really sure what your problem is. When the little tab goes in the slot when weight of bike is applied the jiffy stand can't collapse as it is locked in that position. In my opinion where the stand is now make it's easier to reach forward with you foot to put it back in the stowed position.
Is it possible that your stand is rotated just a bit? Or maybe the cog is worn down?
I don't recall my 2009 RK (I traded it in on this one) doing this.
Actually, I wonder if there is a place that sells replacement stops that are cut at a slightly different angle (like nchogfan suggests)
The wife weighs in about 120. She still panics and grabs it! ...LMAO... I told her, let it go. If it falls on you, my fat old azz may not be able to get it off you....
I have always had sport bikes until this month. The first time I put the stand down on my SGI about freaked out! I am sure it was hilarious to any Harley owners in the area. Today was the first time I felt confident turning the handle bars in the opposite direction while it was parked (had to access a screw to remove the fairing).
