Finding neutral, 2014 ultra limited
Picked up my '14 Limited Tuesday afternoon, loving it! There is one thing I'm wondering about, I'm having trouble finding neutral. On my other bikes when I had this problem it meant that I had to get a small clutch adjustment, that my clutch handle was engaging too close to the grip.
I assumed that was the same problem now, so I took it over to Service and was informed by a Service Manager that this adjustment was no longer possible because this is an hydraulic clutch, and that since I had my rear shifter removed as I always do, it would be easier, and recommended, to tap down with my toe from 2nd to neutral, than to push up with my toe from 1st to neutral.
He said the heel shifter would have made it easier to push down with my heel going into Neutral from 1st. I'm not sure I buy all that, I see no reason why you should"t be able to easily go from 1st to Neutral on any bike with the front shifter. What do you say? Thanks!
I have never used the heel shifter except to try it once. Seems unnatural to me. I cant say I disagree with what you were told but I think you should still be able to snick that up into neutral from 1st gear. Because the clutch is hydraulic, does that mean there is no longer any adjustment?
