CLUTCH CHATTER
Old 08-25-2005, 10:52 AM
Ultralarry's Avatar
Ultralarry
Ultralarry is offline
4th Gear
Default CLUTCH CHATTER
I have an 03 Ultra. When I take off the last part of letting the clutch out chatters. It does not do this in any other gear other than 1st. Clutch seems fine after 1st gear. The only way to not have the chatter, is to ride the clutch all the way out. It does not seem to slip, just chatter on the last part of full realease. Could this just be the spring? The clutch only has 12,000 on it (BIKE). Thanks for any help in advance.
Ultralarry
Old 08-25-2005, 11:15 AM
RoadKing52's Avatar
RoadKing52
RoadKing52 is offline
Default RE: CLUTCH CHATTER
I have an 03 flhrci with the same problem, it seems to do it more when riding 2 up and the dealer told me this was normal. A friend who has an 01 wide glide sayes his does the same thing too. Good Luck and ride safe
Old 01-17-2016, 07:24 PM
kent0678's Avatar
kent0678
kent0678 is offline
Stage II
I have ultra classic with same chatter you guys describe only taking off 1st gear dealer service man said it was normal but my wife's dyna does not do it at all .I guess my question is has anybody figure out what to do or just don't worry about it
Old 01-17-2016, 08:02 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Mine does it and I have read that it could be not giving it enough throttle when letting the clutch out, allowing the compensator to make noise. When I give it a little more throttle on take off, it doesn't do it.
Old 01-17-2016, 08:12 PM
kent0678's Avatar
kent0678
kent0678 is offline
Stage II
Yes I agree if you give it more gas and ride the clutch all the way out it want chatter but i have two more bikes that don't do it
Old 01-17-2016, 08:41 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
I wonder if it has something to do with the type of fluid you are running in the primary?
Old 01-17-2016, 08:42 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,011 Likes on 576 Posts
Have you tried adjusting it?
Old 01-17-2016, 08:55 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
I have the same issue with my '12 TriGlide. Does it after it heats up. Was running Syn3, then BelRay, now Formula+... And they all do it. Took it to the dealer, and they Celine's they couldn't replicate it.
I'm thinking about taking the clutch apart, and seeing if anything obvious...like glazed surfaces. Then put in screaming eagle Spring.
Open to suggestions.
Yup...
Old 01-18-2016, 08:21 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
If fluid does not change it, then it most likely is glazed friction discs, probably from slipping the clutch too much or out of adjustment and it slipping. May need new discs and if the steel discs are discolored then those need replaced also.
Old 01-18-2016, 09:12 AM
Sierra977's Avatar
Sierra977
Sierra977 is offline
Received 3,988 Likes on 2,065 Posts
SE Variable clutch chatters occasionally when cold. Meh. When it warms up chatter goes away.
Quick Reply: CLUTCH CHATTER
