2014 Grips?
I just installed a set of the Harley Aileron on my bike. I had bought them for my 08 Street Glide but never got around to installing them. The throttle side was a breeze just loosen the two screws that hold the switch housing together, slide the grip in and re-tighten. The left (clutch) side was a different story. The Odo/Trip button on top of the left switch housing sticks down into the space where the grip flange fits. I solved the problem by using a dremmel tool to grind a notch in the flange on the grip so that it cleared the bottom of the switch. After I did that everything went back together perfectly.
I purchased 56425-08 Harley grips for my 2015 Street Glide. I had no problem with the right side. I was told that the left side did not need adhesive and the shape of the end would only fit in 1 position in the switch housing. The instructions show the old style housings and the grip will not fit in the housing correctly. I checked the HD web site and it says that these grips will fit on my bike. Does anyone have any suggestions?
