Replaced primary cover gasket and was tourqing (sp) the cover bolts. Was not paying attention and PING! one of the long primary cover bolt bust.
I know... I'm a ***!
After much cussing etc: I looked at saw that the bolt busted right at the end of the threading.
Is there a good way to remove the broken end ?
And is it safe to ride the bike as it is now? All the other primary bolts were installed correctly.
Thanks in advance ! And flame away ! I deserve it lol
No need to worry, carefully drill it out and use a bolt extractor to remove it. Extractors usually doesn't work to great for me and I end up drilling the entire bolt out and cleaning the threads with the correct tap. Take your time and be careful, its not hard to do.
Thank you ! Was dreading the looks if I had to take to the dealer lol
it's probably not even tight. stick a pick or something in there and see if it wobbles. as a machinist i've done my fair share of bolt extractions. best advise is if you're not confident in your abilities don't mess with it! nothing worse than trying to repair a hole that someone broke an easy out or tap in.
You can use a small punch to make a small indentation in the center of the screw then use a LH drill bit with the drill in reverse. Most times the bit will grab and back the screw out.
Not having a bolt on primary cover shouldn't be a problem as long as there is no leak just use some silicone to glue a bolt head in the hole to hide it. I ran into same problem on my 07 UC about 60K miles ago still haven't got around it to get it out.
I will do that until I can get the broken end out .
Thank you everyone
