Custom Dynamic LED's No Load Equalizer Needed For 2014's
#31
#32
#33
I put in the Dynamic Ringz front turn signals last week, and also had the "rapid signal". Turned the IGN. switch on, ran the 4 ways for about 1-minute, and worked like a charm! Also installed a Bright *** tail light - MAN, is that thing BRIGHT! So much, that I can illuminate the inside of my garage in the dark! *LOL*.........
#34
Did anyone installing these in the new Bullet turn signals find them to be a PIA? The flat LED panel does not have anyway to remain positioned as you try to install the lens. Another words it does not grip the housing to stay in place. When you go to install the lens, the LED panel is not longer in alignment as it is cocked under the lens. I ended up attaching the LED panel in between the tabs of the lens but that caused it to be difficult to install the lens as the LED panel was a tight fit and caused the lens tabs to loose their flexibility.
#35
#36
I found that the CD flat panel LEDs fit deep enough into the bullet signal housings to allow the lenses to snap into place on the front,but the rear Dynamic Clusters were a different story.For the rears I filed down the perimeter of the disc,maybe only taking off a mm or so.Now the disc fits snuggly in the lenses and the lense snaps into the housing.
#37
I was trying both clear and smoke. The lens is fine. It's the fact that when you put the panel between the tabs it makes the stiff. I ended up using a rubber mallet to snap them into place. Seems fine, just not an easy installation if you want them to be straight.
#38
DeiGratia
02-04-2013 04:54 AM
