Replacement Road King windshield grommets
I need to replace the windshield docking bushings on my Road King.
Where I live, 'BUSHING (4) Part No: 67621-94' ... to give then their full name, rank and number ... are listed as $10.93 + 20% tax if I was to pay it ... $52.46.
Thankfully, Drag Specialities does a set of 4 for $19.95.
I'm also interested in the idea of ShieldShackle because I never been able to work out what that damn piece of bent wire was supposed to be doing ...
My question is, has anyone ever tried knocking up their own bushings out of stainless steel or some other metal?
I'm thinking plain metal bushings and a ShieldShackle type device is going to fix and hold the fairing in place far better without any wear.
Yes, I know the trick of giving them a half turn to get more life out of them, but I think I have used up all their extra lives.
Thanks
(BTW, I don't add any green links to my posts, it seems the sponsors' advertising system does).
Thanks
I too was rather taken aback at their price. Though I was given a lower price than you.
I thought about using a square o-ring and washers on the side, either stainless or fiber. Didnt do it as it just wasn't worth my time. I'd be a little concerned about buzz with metal side washers.
I will try to remember to look for cheaper alternative grommets at the next big auto swap meet.
The key to making them last (as you might expect) is to minimize the number of times you take the windshield on and off. In addition to that, I spray the grommets with spray cleaner before I install/reinstall the windshield. That kind of lubes them and makes the brackets less likely to tear the rubber.
Received 2,524 Likes
I saw a jerk salesman showing someone the "Detachable Windshield" on a showroom bike once, He snatched it off, then jammed it back down trying to force the spring clips down, slapping on the top of the shield like a fool. I remember him saying something like "It comes off in a couple of seconds, but takes half an hour to get the damn thing back on!"
Line up the two bottom carefully, then ease the top ones in, it's a piece of cake.
You can properly remove/replace them a hundred times without damage; or force them once like a jerk, and they are shot.
The following 2 users liked this post by giacomo56:
rideerr (12-19-2020),
Superdog3:16 (05-27-2021)
Almost the whole of the rest of the vehicle is metal to metal bolted together.
As it is, I find I tend to loosen and then bolt into place the windshield when using it ... and what those damned spring clips are meant to be doing except for getting in the way, I have not a clue in hell. I may remove them.
I have the ShieldShackle on my RK. They are just the thing for keeping the shield secure and difficult to steal. BUT....they also make removing the shield a pain in the ***. It takes the special safety-Torx wrench (included) and a 7/16 wrench to get the damned thing off, and that's AFTER you remove the chrome bolt-head covers (also included, IF you use them). I don't remove the shield, so I like them. Summary:......the ShieldShackle is a great anti-theft device, but if you remove your shield frequently, you'll learn to hate it.
Yah, there are quite a few of those on an old Harley ... I think they are cleverly designed to psychologically hook those individuals with love/hate complexes, or even "rescuer types". ;-)
