Jackpot 2-1-2 Questions
2013 FLHTCU
For those running the Jackpot, are you using the stock cross over or did you go with the Jackpot full size X-over? Are there any gains with going to the 2-1-2 "High Output" header when I really don't plan on doing anything but the cams later? Also, I couldn't tell on FMs website, but I am assuming that the O2 sensors bungs are in place.
Here's what I am thinking:
Jackpot 2-1-2 SS Head Pipe
Jackpot 4" Mufflers
Power Vision tuner
I already have a Ness Big Suck A/C installed.
Jackpot 4" Mufflers
Power Vision tuner
I had one on my 12 SG for a while, great power. I used the stock crossover, in talking with FM, they say you dont need it unless its a Hot 107 with cams ported heads etc. It has O2 sensor bungs in both locations for an 09 or the 10 and later bikes.
The combo your planning is very proven here and on the FM website.
If you plan on limiting your performance upgrades to the Stage 1 level, then a stock, de-catted header will offer a similar bump in performance as would the other popular header options (Fuel Moto, Full Sac). I see no need to spend more money to attain a similar goal. Stock, de-catted headers can be had by a few Ebay Sellers for around $135, shipped.
If your plans include a Stage 1 upgrade AND cams only, then I still think that a stock, de-catted header will work for you. Going any further with performance mods would probably be best served by an aftermarket solution.
Hope this helps.
I have 4" Jackpot Dyno Tuned mufflers along with Fuel Moto's Pro Billet Stage 1 air cleaner and a stock, de-catted header. I'm also using NightRider's FL-XiED-10 kit for fuel management. My SG runs great and provides all the performance that I would ever need. I don't plan on, nor do I have a need for, any future performance mods.
Hope this helps.
Hope this helps.
I run the 2-1-2 with the stock cross-under pipe. It's appears to be the same size pipe as what they are offering in their "full size crossover", just flattened a bit to allow the clamp to hold it snugly in place...and to allow a little more clearance under the bike. It's certainly not worth what they are asking for it in my opinion.
Fender guy has his opinions, however, the stainless header from FM is much better quality than the stock header. It's lighter, more robust up where it fits into the exhaust gasket, and the collector is engineered for a better balance of air flow between the left and right muffler. There is little engineering in the collector area of the stock header. The stock gutted pipe is cheap and for those that go cheap, well, it works for them.
The FM header comes with O2 bungs up near the exhaust ports (where they should be) and also down at the location where the current narrow-band stock O2s screw in on 2010 and newer models. FM supplies bung plugs for the bung locations you don't use.
Check out post #250 on this link
https://www.hdforums.com/forum/touri...l#post10574817
Fuel Moto used to have a comparison dyno sheet on their site. If I remember correctly, there was a little over 1hp & 4tq gain with the Jackpot 2-1-2 over over an 09 (I think) catless stock head pipe.
The full-size crossover is a little bigger in diameter, but it's not crimped, so it presents less restriction. I don't know that I'd bother with it on a Stage 1 103. I like it on my 110. There is simply no comparison between a de-catted stock pipe and a Jackpot pipe. The Jackpot is worth the money in power, flow, and temperature. Similarly, there is no comparison between a gimmick like the XIEDs and a proper tune.
Do your Stage 1 right, and you'll have a faster, smoother, cooler bike that gets better mileage than anyone with a de-catted bike and XIEDs.
