Compensator time, again!
Well I'm getting all the same issues as the last time I had to replace my stock compensator with the SE compensator "A" type. I have over 20,000 miles on my current SE comp and not happy I have to replace but that's how it goes.
I've been using B&M trick shift non-syn for my Barnett clutch pads "as they recommended"but plan on going back to Harley syn when I install this new comp and my Bandit sportsman clutch. I ordered the new comp with plastic piece and the glue install kit together from Kutter Harley online for $282 shipped so I'm glad I found that site. Since I have the old SE comp I don't believe I need to order any additional parts but figured Id ask here first.
I have already read about all the concerns with the needle bearings and gluing plastic into my primary but I think I'll give it a shot anyways. I see the new model primary covers have the updated oiling sumps that the plastic glue on piece provide for us with out it, but I'm not ready yet to purchase a complete cover just for that purpose.
One thing I'm wondering is about this super aerospace glue that is to be used, I also have the stator wire oil leak that I band-aid fixed with high temp gasket maker. I wonder if I could add some of this glue to the inside of the primary around the stator wire to stop the leak from the inside, is that just dumb or any logic to why it wouldn't work? I don't feel like having to replace a stator as well just because it leaks were it comes out of the primary. Or should I say it was leaking before I added the gasket maker, that was years ago. Adding the glue on the inside would just be extra insurance that another leak would not start from the same place.
All the threads on the different forums that I have read are positive so from the members that have installed this new comp but it to early to know how long this one will last, time will tell.
Any other input welcome.
Hope that helps you and/or someone else.
TIm glad Im not the only one who thinking out loud, it is something I do all the time and common practice amongst the outside the box thinkers...Id like a buck for everytime I keep myself awake going over stuff in my head. You keep bouncing ideas around the forum, I for one will be reading, let us know how it turns out.
If it is the same glue and plastic piece Harley uses at the factory, they back it for 2 years and unlimited miles with the option of extended coverage after that. Follow the directions and it should be fine, just like the liquid cooling system. Seriously, when the time comes, I won't worry about that part falling off.
I have an '07 Fat Boy and purchased (from someone on this forum), but haven't yet put on, the 40274-08A compensator. Then this new one comes out, part no. 42200064. That one says I'll also need the rotor assembly, part no. 30041-08. So, I asked the MoCo via e-mail whether the rotor with 40274-08A is the same as 30041-08. I received a prompt answer, which is "yes."
