Changed windshield. What the heck!
I changed the windshield on my 13 UC and the small knurled brass inserts were not lined up. What a pain in the a**. Finally got 2 screws in but one cross threaded and the brass insert started spinning. Not good. Finally pulled it out right thru the fairing. This seems to be a bad design. Anybody else ever have this problem and is there a trick or better method of changing a windshield. Gotta figure out how to get that brass insert back in. dosnt look fun. thx in advance
Yep. they can tend to do that...
Go to your local dealer and buy a package of the inserts, be sure and take astroglide...
or
Take the faring off, locate the hole where the brass insert goes, clean it out best you can with a rat tail file and superglue the sucker back in. gorilla glue works even better.
Once it's dried, you can then put it all back together.
When putting it all back together, get the two screws on the outer edge started, then the two screws underneath the faring between the forks and then the middle screw followed by the two at the each end of the windshield. You can also do the middle screw first, but that takes half the fun out of it..
now adjust the faring to fit as best you can and tighten from middle to outside and then down...
Please make sure you don't have to take a leak while using the glue...don't ask...and be prepared to use words you never thought you'd ever have to use. The faring responds well to this kind of encouragement...
Good Luck!
or
Good Luck!
The windshield can be removed without taking the screws all the way out. I have found that if I loosen them until there are just a few threads left, the windshield comes right out by just pushing forward at the base of the shield at the screw attachment point. If the screws are removed, I have found that by pushing down on the outer fairing right at the screw attachment point they line right up.
