2014 Street Glide 500 Mile oil question
Old 10-12-2013, 10:04 PM
BKSinAZ's Avatar
BKSinAZ
BKSinAZ is offline
Default 2014 Street Glide 500 Mile oil question
Just reached 500 miles and I was going to change my own oils as I have always have done.
I noticed that I had 4 quarts of Castrol Power RS V-Twin 20w-50 and
3 quarts of Valvoline 4tstroke motorcycle oil 20w-50 laying around in my work shed. Both are Full Synthetic.
Question... seeing how I got this oil, I don't want to waste it. Can I use it in my 2014 Street Glide 103? Can I use it in the transmission and the primary? Would one brand be better in the tranny vs. the primary vs motor?
At the next 500 mile service, I planned on getting Redline motor, tranny, and gear oil. But for now, I just cant see spending the bucks.
Old 10-12-2013, 10:08 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
my rule is any motor oil in the motor,gearlube in the gearbox,and anything that says v twin in primary,v twin doesn't have additives that will lead to clutch slip.
Old 10-12-2013, 10:22 PM
Hulkss's Avatar
Hulkss
Hulkss is offline
Received 1,848 Likes on 975 Posts
Read this and decide for yourself:Oil Study
Old 10-12-2013, 11:03 PM
BKSinAZ's Avatar
BKSinAZ
BKSinAZ is offline
many people put moble one vtwin in all 3 holes.
Old 10-12-2013, 11:05 PM
BKSinAZ's Avatar
BKSinAZ
BKSinAZ is offline
so are you saying its ok to use?
Old 10-12-2013, 11:11 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Yes, by all means.
Old 10-12-2013, 11:15 PM
ynots's Avatar
ynots
ynots is offline
Go for it, it won't hurt a thing but if your going to change it again at 1000 service I'd just use a cheap dino
Old 10-12-2013, 11:27 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Wouldn't hurt a bit to use it.
What I've learned:
....and on the record, I hate "branded" oils as a rule, from Polaris snowmobile to HD brand....
Harley Formula + is the best I've found in the primary.... ESPECIALLY if you have a hydraulic clutch. And I've run everything. Drag Specialties primary fluid isn't bad, but tough to find.
In the engine I prefer Amsoil 20w50 VTwin, and in the trans I run Amsoil Severe Gear 75-110
Old 10-12-2013, 11:29 PM
SafetyMan's Avatar
SafetyMan
I wouldn't do that, and here's my reasoning:
You never empty all of the oil during a service. There is still 8-12 ounces of fluid left in the engine after you drain it, roughly 8 ounces in the primary, and about the same in the transmission.
Switching to a product that is closer to what you are going to run on a permanent basis will start thinning the old stuff out sooner.
Would it hurt to go cheap dino? Nah, not a bit.
Old 10-13-2013, 02:33 AM
jakejohn's Avatar
jakejohn
jakejohn is offline
Just wondering why the change at 500 miles.The MOCO recommends first service at 1000.
Quick Reply: 2014 Street Glide 500 Mile oil question
