Fuel Filter Question?
I've got an 05 EGC and I'm doing a 25k service on it (I've actually got about 26+k miles on it)
Went to my local dealer to buy a fuel filter and they wanted $85 just for the filter. Then he suggested I change the little plastic "crush" screws as well as the plate and gasket. All said and done, it was gonna be over $100.
2 questions....
1. How critical is it if I don't change the filter right away? I've got 200k miles on my car and never changed a fuel filter. Never had any problems. (Although I think I know the answer to this one)
2. I've been reading previous posts(yes I do use the search function). But couldn't find anything specific to an 05 fuel filter. How difficult is it to do? Or should just save myself the aggravation and have my shop do it?
Thanks in advance for any suggestions!!!!
2 questions....
I have a 2006 Road King Classic with 43 K and do all my own servicing. I have not changed my fuel filter yet and have noticed no ill effects. I have read numerous threads of others that had changed theirs and reported the filter was dirty but probably did not need to be changed.
I did however fell it was necessary to change out my cam shoes before I got to 25k. Those were found to have minimum wear but changed them out anyway with the new upgraded oil pump.
It's not hard to change the filter. Assume we are talking about an injected motor, right? If so, the filter is in the tank. There are a couple of threads on here that have pictures showing someone doing it. My '07 didn't take too long to change but the real b**** was getting the new flexible hose back on the filter because it was such a tight fit. I changed mine at 40k and just did it because I didn't want to get stranded somewhere. No issues at the time of change though.
Yes what he said. Drag Specialties came out with the parts too and much less. Just because your car did get a new filter doesn't mean it should not have been done. I do all my vehicles at 30k. Bike was done at 25k.
Drag Specialties makes a filter, line and oring kit for half the price of Harley. I am in the process of changing mine right now. Check the other fuel line in the tank for excess wear marks. You may need to change that too because the rubbing on the inside of the tank will create pin holes. If you do, drag specialties makes a kit that is much cheaper than Harley. The kit will come with a check valve and new plastic line. Good luck.
