Auto speed volume not working
Old 10-16-2013, 08:37 PM
eazyduzzit's Avatar
eazyduzzit
eazyduzzit is offline
Default Auto speed volume not working
My stereo has stopped automatically adjusting volume when speed changes. It's an '08. Anybody know a fix for it?
Old 10-17-2013, 12:31 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
you have the AVC set for "on" using the radio menu ?
mike
Old 10-17-2013, 10:24 AM
btsom's Avatar
btsom
btsom is offline
Presuming the basic settings are correct, this can be the first symptom of speed sensor failure or contamination. The speedo becoming erratic or failing and the turn signal auto cancel failing are the other indicators of speed sensor problems. Pull the sensor and check for fuzz and clean if necessary.
Old 10-17-2013, 10:33 AM
GoGetter5832's Avatar
GoGetter5832
GoGetter5832 is offline
I've never had this feature until I got my 2014 SG. I do have a question to those who have used this feature. Is the music supposed to get quieter when you are coming to a stop? if so, how can I make this feature work? I feel that my music does get louder while my speed is increasing.
Old 10-17-2013, 10:40 AM
mazz's Avatar
mazz
mazz is offline
yes the music get softer as you go slower ,did they throw in a manual with that $20,000 bike rtfp?
go thru the radio or display setting until you see avc that is what it is called on older bikes
Old 10-17-2013, 11:13 AM
GoGetter5832
"$20,000 bike rtfp" thats your reply?? I Just saw the thread and thought I'd ask a quick question since the volume does get louder while speed increases and doesn't get quieter while speed decreases. Hoping another Forum Member would have a quick answer. I've gone through the display settings, etc. That's why I asked.
Old 10-17-2013, 11:30 AM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
On mine you get to the avc by pushing the volume button and scrolling to the avc adjustment. It will have a couple of different settings. When working correctly you won't even notice it is working. The volume will still be very loud if you stop the bike. I don't know if it works when using head set, never noticed. It can get turned off somehow. I think mine got reset when changed battery. Your owners manual is a good place to find out more about it.
Old 10-17-2013, 11:34 AM
JimmyDee's Avatar
JimmyDee
JimmyDee is offline
I am not in front of my bike at the moment, but I believe that if you press the volume switch you will be given several options. IE: base, treble, etc. one of them will be AVC (automatic volume control) choose it and you will be able to adjust the AVC to your preference. The louder the ambient noise the louder your radio volume will be.
Old 10-17-2013, 11:44 AM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Press in on the volume control on your handlebar. One press brings up bass... two brings up treble ....three depends on options on your bike. Just keep pressing until you see AVC. Then up/down volume to change the setting. I like III
Old 10-17-2013, 11:46 AM
GoGetter5832
Gotcha. I have done all of that. I just wish it had a volume setting for speed and one for "stand still" or similar. It would be great if when I was decreasing to a stop that I could set the volume to a very low level because I find myself always manually turning it down so I can talk to the people riding with me. Thanks for the replies!
Quick Reply: Auto speed volume not working
