Replace SE Compensator - Dissater!
I followed the instruction from the other thread. Everything went smooth, and I finished the work within 2 hours.
This SE compensator is the previous version of the latest one that requires new rotor and adhesive kit. I bought this set almost two years ago.
Anyway, turned it on and I immediately heard some rattle noise from the rear area (clutch), which I didn't adjust anything at all, but I did checked for the spec.
I decided to ride around the neighborhood to see whether anything may be improved. It was getting worse. It sounds like shaking a bowl of marble *****.
Anyone has a similar symptom?
For sure I have to take it apart next week (go back to work tomorrow).
Thanks much in advance for any info.
Nick
Nick
Yes, I did.
For sure, this will not help or cheer me up at this situation.
Ya know, at 10k I replaced my 2010 stock with a se unit because of all the threads on failed stock compensators, first of all my stock was in perfect shape, but since I had the se unit already I stuck it in. I have about 3k on the se unit and really cannot tell any difference, good or bad. This dec. I will probably take the primary cover off & check it all out, I've seen the se comps wrecked. On your problem I would take it apart asap, it shouldn't make any more noise then stock, something's wrong.
