Engine Oil leaking into primary
My Bet is on a bad crank seal. It happens from time to time with those results. If the seal is bad enough crank pressure will push oil and air out of the stator seal along with forcing oil into the primary. The stator seal is not made to handle that type of excessive pressure like you would find in a crankcase. On idle, the pressure is less and will tend to follow the normal venting process but on higher RPMs and crankcase pressure, the pressure will take the paths of least resistance. Check that seal..
Based on what you've posted here already, my next step,would be or pull the outer/inner primary and inspect the crankshaft seal. With your breathers passing pressure, it sounds like the oils is being pushed into the primary from the crank seal.
These motors are easy to work on, especially with a service manual. With your background on cars, I wouldn't let the unknown keep you from diagnosing/fixing this yourself.
Good luck!
Good luck!
That vent hose is for the transmission. He said he was a quart Engine Oil Low and overfull in the primary.
The only way Engine Oil can get in to the primary is thru the Crankshaft seal located behind the Stator Rotor. And the overfilled primary will push oil out of the stator plug that passes through the primary.
A defective seal, bearing, breather valves or crankshaft run out could cause this. I would suggest that if it was crankshaft run out then you would have much more noticeable problems over on the cam side with the oil pump and other things that result from it being out of spec. It needs to go to a shop.
If I am not mistaken, the crank case also breaths into the transmission. On older TC's the crank case had a vent hose going to the transmission, then the transmission vented through the hose hose from the transmission. The newer models, again if I am not mistaken, now uses a passage in the transmission mount to the back side of the crank case.
If I am wrong, the cost of checking the hose is nothing but time...
If I am right, the cost of fixing his problem is still nothing but time...
How much time would it take to remove, clean, and replace that hose? About 4-5 minutes? If nothing else, you know the vent is clean if you check it!
Thank you for the feedback though.
Marc Gonzales
06-30-2013 12:36 AM
shiny2003
04-15-2008 02:23 AM
