Xm antenna
JB welded a piece of 1/16" thick metal to the top of the front master cylinder for antenna magnet to grip. Great reception and no obstructions. Cut metal same shape as antenna pod and it looks like it is just sitting up there all alone. Looks cool and easily removed if needed.
Received 2,524 Likes
Shoot straight about antenna location, folks.
My factory GM XM Antennas on my vehicles pick up as good as can be achieved.
Note they are located high and above obstructions.
Anything that comes between it and the satellite will interfere with reception.
Bridges, overpasses, tall condos, trees, all can mess it up.
In the U.S. the signal can come from south, southeast or southwest of your location.
It is the nature of the beast.
On the bike, a good open sky location that does not make YOU the obstruction will serve you best.
Low on the bars in front of you may be a problem if the signal is coming from behind you (Helmet could block it too!).
Windshield would not be the concern in that instance...
They try to bounce the signal off of two or three sats at a time to reduce the effect, but switching is not an exact science for this market. OnStar, for example, relies on multiple fixes to enhance location for their program. XM has not progressed so well in that area at this time.
Not meaning to get off task, just lettin' ya know...
