installed a set of 2+2 on the 14
just installed a set of Khrome Werks 2+2 on the Limited I internal wired it also installed a hidden antenna and I picked up a garage remote off ebay for 20.00 and did some wire work and installed it inside the fairing with a small button.
Only problem was using the cvo 32310-08 sensor kit see
https://www.hdforums.com/forum/gener...2310-08-a.html
Hey thanks for the post...question I want run these on my 14 FLHXS. I assume they will interfere with mirrors on batwing? Also did you have to change out the TBW or did you choose to do that. I would like a swap without any added glitches. We're you able to just pull or did you have to reroute cables for brake and clutch? Thanks in advance..
I have HD 2" pullback touring bars installed on my '14 Limited, I believe they are 1 1/4" diameter. they are not working for me, don't come back far enough, are these 1 1/4, it looks like they're up and back, do you think these will give me the pullback I need, how much of a pullback are they over the HD 2". Do you have a model #? I'd like to check them out on line. sorry for all the questions, but I really need a pair of comfortable bars that I don't have to lean forward to reach. thanks.
http://www.khromewerks.com/ part#300517 click on products then go to handle bars and go to the bottom of the page and click on handle bar specs and you can see a drawing with specs.
They are 1" bars and are drilled for internal wire.
tesnevo
2014-2023 Touring Models
15
10-23-2017 07:37 PM
