14's Air Cleaners
I was told by my mechanic that the Heavy Breather will out flow most by just a bit. He said that until you get passed stage one with cams they will all flow more than the motor can use. When you get into big bore kits with ported and polished heads there might be a limitation on some of the more restricted AC. No proof of this just passing on what I was told by a trusted mechanic.
Sent from my iPhone using IB AutoGroup
Key word here was stock bike. I don't have any hard numbers but I would be willing to bet that "4 Rineharts with VH Power Duals and say my SE Ventilator would make more power than the same exhaust with the stock AC setup with just a K&N filter. And if you ever do cams or big bore kit you would want a true high flow filter system. The stock AC has the one area to suck air in where a completely open AC like the Ventilator can suck in air everywhere. I say go with an open element filter from the beginning and your set with just about any build. Some of the AC are a real work of art IMHO but I went with reasonable price and good function...lol
Any A/C unit is better than Stock. Stock units are like sucking through a straw and your motor needs to breath better than that. As Webo mentioned, they all will perform well until you do that awesome build that requires anything but exceptional. putting an K&N filter in a stock housing, unless we are talking the '14 housing which has a nice "forced' opening on it, is not much of an improvement if your doing more than A/C. Alter the exhaust and all, you need more air, Any Stage 1 will do or better.
I think that removing the stock backing plate is what makes the biggest difference because that allows it to suck fresh air from any direction. If you went with say the Arlen Ness Big Sucker and used your factory cover that would allow much better air flow and still look factory to some degree. Anyway here are the pics you asked for. You can only see the wire just a bit on the left side. The Ventilator is oval so it covers the box up completely.
