Head pipe cracked-keep jackpots?
I have a 07 SG that has a crack beyond repair. I recently put on some Jackpot slip ons which are intended to work with stock head pipe or aftermarket pipe with crossover from what I read.
The fullsac true dual conversion surely looks good for a budget replacement. So besides finding a stock head pipe that is prone to cracking, is my only other option under $200, to go full sac and sell jackpots for other slip ons?
I guess I'm curious if its just not ideal to pair true duals with jackpots or if its more than that. I've read one person say the rear cylinder and left muffler would heat up due to increase in flow to muffler. Any truth? Anyone with jackpots and TD's want to chime in?
alot of the stock pipes do crack at the Y joint- this is sometimes a result of the owner banging on the slip ons, trying to get them off...or back on.
easily welded, easy to replace w/ cheap take offs.
you may be able to save a few bucks here.
if true duals is what you gotta have...the $4 freeze plug conversion works.
mike
mike
My father is a welder but this crack is pretty narly in shape and actually runs down the pipe as well. even he recommended to let them go instead of trying to fix.
Maybe I should add its in two pieces now. Maybe I should change the thread title. Haha.
I am looking to score a stock set though. Not hits yet.
thanks for your input.
Steve
I had my head pipe crack last summer ('11) and replaced it with a set of Vance and Hines True Duals and put the same Rinehart slip-ons back on. There was a nice bump in power (seat of the pants) but as said earlier regarding some of the other headers, the heat increase is pretty dramatic on the left side and seems even to have increased on the right side. Go figure.
07 SG - I had 2 rear Y pipes crack within the first year I owned it, the cause according to HD was extreme heat & replaced under warranty. When the 3rd one cracked, I put on V&H Duals, it definately reduced the heat froom the rear exhaust & no more issues. I do recommend kicking the stock exhaust to the curb...
