Lowering Street Glide question?????
I have changed my seat to the sundowner on my 2009 Street Glide. I really love this seat but I can't sit flat foot on the bike. I don't want to change the shocks. If I change the front wheel to a 19inch would that lower the rear so I can put my feet on the ground? I have the stock wheel now and that's a 17inch.
I'm 5ft 7in and 200 Pounds
Any suggestions.
Merry Christmas and Happy New Year!!!!!!
Any suggestions.
Lowered front and rear
Mine is lowered 1" in the front using Progressive spring kits and lowered the same in the back with shock blocks. Some owners will tell you that the blocks mess up the geometry on the shocks but...couldn't prove it by me. I really like the lowered chassis cause I am short legged and can now sit flat footed on the ground.
One thing to consider is the lost ground clearance you will experience lowering the chassis. I will say that I have had little or no clearance issues. Just be aware that could happen depending on your riding style.
Received 3,939 Likes
Any suggestions.
Any suggestions.
when looking at stock hd tires/wheels, the 16'', 17'', 18'' and 19'' all have virtually the same overall diameter. the 17'' is actually the tallest of the 4, by a couple hundred thousandths of an inch.....
I would not lower it any more than a 1" fork kit. IMO any lower in the rear is too negative to the handling. If you need the footing go to a drop seat kit like the FBI kit it will get you a couple inches lower without loosing suspension travel. Or add a inch to your riding boots or try a C&C seat it will lower you 1.5 inch over stock
