Gear Shift Linkage
Gear Shift Linkage
Finally changed out the stock gear shift linkage. I followed the instructions for the new one but there was no way the front linkage would fit on the inside of the shift lever so I installed as shown in the pic. But the linkage is not straight to the back lever. Do I need to adjust the front foot shifter to bring the shift lever forward and then install the linkage on the inside?
I did but the only way to get the front on the inside without hitting the jug would be to move my foot shifter.
looked at your picture again. i'm feeling kinda punky today so i missed it the first time around, but it looks like your shift likage is on the outside of the levers, ie further away from the engine. that is how it should be. mine is the same, only the bolt is pushed through from the back and the nut is on the outside.
the important thing is, is it binding anywhere or is it allowing you to shift smoothly? if smooth, then no worries.
