Garmin Zumo GPS Work With Navigation Interface?
I originally posted this in the Audio sections but no replies. Guess no one over there has had this question come up or no one has tried to use a non Road Tech GPS with the Harley NIM unit.
First off i have done a search for this but really ddin't find an answer for this question.
I am looking into getting a GPS. Garmin has a Zumo 390 I like with some options that are not on the 660. Mainly the Curvy road feature and exit services. Plus if wanted to it has the service logs and tire pressure monitoring system too.
My question is this, if I was to use the NIM from Harley in the instructions it says the GPS ( Road Tech ) must have a certain software update to be able to use the NIM. Does this unit ( NIM ) only work with the Harley Road Tech Zumo's or can it be paired or used should say with a Garmin unit that is not Harley's Road Tech GPS's?
I am thinking of having Iron Cross install the Bluetooth when I send my radio to them for the backlight color change. They have replied to me saying if this is done then they have to disconnect the Aux because it is used for the Bluetooth. If this is done then the Aux cannot be used for the Aux connection for the Garmin ( non Harley ) GPS and will have to rely on the NIM for my turn prompts.
Also on some sites it is showing the Road Tech 660 as being obsolete. Anyone know something on this?
Bottom line question, does the NIM only work with Harley Road Tech GPS's? Has anyone used a Garmin Zumo GPS that is not a Harley Road Tech with NIM and have it work?
Received 2,524 Likes
Do you really like the curvy road feature or have you used it yet? Have you got it hooked up to the Aux jack or did you go Bluetoot?. Where did you mount it?
Yes, the NIM ONLY works with the HD Road Tech 660 or 665. No one has had another GPS and made it work with the NIM.
Someone above already mentioned this, but I will again, the NIM requires a digital pulse wave (in the beginning used a tone) to activate the mute on the head unit and push the spoken directions. This is only in the firmware for the RT units, the other Garmin units use different firmware. Even a Garmin Zumo 660 uses different FW than the Garmin RT Zumo 660.
Steve
It's one of those, "What the hell?" kind of things...this should absolutely work! I don't know if it was intentional, but I suspect it was on the MOCO's part. It has been researched to death but the results are always the same...it will not work.
Having said that...I purchased the Road Tech version of the 660. I have been very pleased with the unit. I use it in all of my vehicles and keep it updated with respect to maps and firmware. It's a well made piece of electronics.
I hope this helps...
Steve
Steve
As stated, I am diggin' it, but man it is pricey!
It's what you pay for the latest, greatest, I guess...
ghostrunner
Audio Systems
01-20-2014 08:17 AM
