Oil pump alignment
As a suggestion buy the pins and do it correct. I just had my motor done at a shop, in 1k miles I lost the oil pump, the inners was all scored up, the symptom was a severe drop in oil pressure. Fast forward to today now with 6k on it I lost the OP again, Im tearing the motor down next week, and after conferring with at least 5 top notch techs (not including the idiot that did the motor) there is a high degree of probability that the pump is wiped out again, and probably due to pump misalignment.
Hope it works out for you.
I would say yes to this. In my manual it says to loosen oil pump bolts a quarter turn rotate engine for pump to find it's natural centre. That is the way I did mine and have had no problem with oil pressure
This is a very confusing issue to me also. Best I can tell, Harley does not dowel the pump since the newer TC's can have runout on the crank. The area of the crank with the two flats on it that drive the inner rotors of the oil pump are a loose fit. So hence, if you snug it slightly and turn the motor (using rear wheel) the crank shaft will bump the inner rotor and align oil pump so the inner rotor does not bind it to the outer one. However, the service manual shows using the two threaded studs with the angles on the stud like a pointer. Any machinist knows centering off threaded holes is a sorry way to center anything. When you screw the centering studs in, are they in a clearance hole in the cam plate and only touch the oil pump.. If the threaded holes are true to the crank pin, why did Harley not dowel it?
page 7 of this shows using the alignment pins.
Do you really need the gear locking tool to break the sprocket bolt or torque it if motor is in gear?
http://harleyhog.host.sk/tensionerinstall.htm
