How To: Hidden Axle on a bagger
This thread shall serve as a "How To" for installation of any hidden axle. A hidden axle is sure to clean up the front end of the bike by eliminating the bulbous ends of the stock axle and/or axle covers which stand out like a sore thumb. If you think like I do clean lines are what you are after, not bulky chrome covers.
Tools needed:
1/2" open end wrench
3/4" open end wrench
10mm 12 point socket or wrench
1/2" and 3/4" socket with ratchet
Remove the brake calipers from the lower legs with the 12 point 10mm socket or wrench.
Step 1. Remove the current axle, making note of axle spacer orientation. Prepare to install the captive nut(splined cap with internal threads) into the left (sitting on the bike left) fork leg. Thread the 1/2 20 nut on the bolt all the way up to its head, then the washer.
Step 2. Insert the bolt through the axle hole from the inside of the fork leg. Thread the captive nut onto the bolt as far as you can by hand.
Step 3. The nut is used as a puller. As you tighten the nut with a 3/4" wrench the captive nut will gradually insert itself into the leg until flush.
Step 4. Once the captive nut is pulled in flush, back out the bolt from the leg. The captive nut is now securely in the lower leg.
Step 5. Install the wheel with the spacers in the correct positions. Apply anti seize to the axle and thread the axle first into the captive nut by hand.
Step 6. Use a 3/4" socket to tighten axle.
Step 7. Use a foot pound torque wrench to tighten the axle to 50-55 ft lbs.
Step 8. Slide the second cap with the o-ring into the lower leg.
Step 9. Install the right lower leg clamp using a 1/2" socket, torque pinch bolts to 11-15 ft. lbs.
Stand back and admire your clean lower legs with the new hidden axle.
Tools needed:
If you are going to keep your stock legs this is the way to go. I think the bike looks much cleaner with a hidden axle than with axle covers which tend to stand out like a sore thumb even if they match the legs.
The hidden axle costs a little more but you get a lot in the way of clean looks for the price difference.
