What does this plug go to ? Pics
Its a service only plug in the bottom of the crankcase,,actually in the cam galley. Even though a Harley is considered a dry sump motor, the level of the return side of the scavenge side of the oil pump is apx 1 1/2" off the bottom leaving about 12-20 oz of oil that is spun by the crank. This lubricates the inner cam bearings. Somewhere there must be an exact amount so if there is a sign of oil sumping in the motor a mechanic can check the amount left at a level shut down. Your actual engine oil tank is the pan on the bottom of the transmission and of course a plug that has a passage way up thru that tank to the transmission. Oil drains are actually hex bolts along with the allen wrench hole in them.
Yeah located the three 5/8 drain bolts with Allen holes in them . Just also noticed a few other plug style screw ins and was wondering what they went to .
Haha exactly . I'm guessing since it's motor oil if you drained it it would just fill back up when the engine is running but it would be dry for a few seconds before the oil got back to it .
So that's not the same bolt in our cam galley on our Softails? Only thing in my 2008 service manual is to use loctite sealer on the pipe plug. Not long ago, some one indeed tightened the NPT tapered pipe plug in and cracked a big hunk out of the side of the block
