Leaking master cylinder cover winded but may be worth the read?
I think I might finally have it? I've tried everything to get my weeping master cylinder cover to stop leaking and shooting little droplets of DOT 4 back on my bikes paint when in the wind. I disassemble it, clean up the cover, lip and gasket with soap and water and alcohol, reassemble and ride for a few weeks and do it all over again. I have the third revision cover and gasket and the new torque specs of 6 inch pounds down from 12. I've used a crappy little beat up torque limiting screwdriver because its all I could find that went down to what I thought was 6 inch pounds. Last week I finally broke down and went to Seekonk Precision tools and bought a high quality, guaranteed certificate calibrated 0 - 40 inch pound torque limiting screwdriver and I also bought another new gasket. Before I went through the whole cleaning and new gasket ritual, I checked the torque with the new driver. I was shocked...6 inch pounds on the little screws and rubber gasket is a lot more than I would have ever suspected! The old torque driver must have been in inch oz not inch pound. I very carefully torqued to 6 inch pounds and it was much tighter and compressed that gasket much further than I had ever done. It obviously wasn't to the stops, but it surprised me at how much tighter 6 inch pounds is on those tiny screws and a rubber gasket. I rocked the bars back and forth and squeezed the brake lever etc. looks good. I guess the first ride will be the tell all....Those of you who think you can feel 6 inch pounds and your just snugging those screws up would be surprised...Its tighter than you may realize.
I had the same issue. I picked up the third revision gasket with a new cover as well and so far so good. The third revision does not protrude under the cover like the previous version so I was skeptical, but his revision seems to work well so far, time will tell. I was told if the gasket is ever over-torqued, you might as well toss it.
Your right Dawg, they only sell as a kit from what I'm told. However, I asked Wilkins if I could buy just a gasket and Mike went out back and found one and sold it to me. The baggie it came in had the following number on it..42857-06B. I don't know if that was just a baggie they had laying around or if that is actually the gasket number?
