Anyone running Bel-Ray 15w fork oil?
Gathering what I need to change the fork oil in my '12 Ultra, and came across the Bel-Ray fork oil on Amazon. I want to go a little heavier, I like what I read about the guys that have done so. Just checking to see if anyone has used this brand, and to make sure that 15w is what I want to go one step up from OEM.
Thanks
David
Thanks
David
I went with Amsoil shock therapy #10 in forks & stock air shocks it rides real nice now I think that #15 is to heavy. Stock is #5 HD "E" type I believe. You really can't improve the air stocks to much but Amsoil #10 did alot more than what I thought it would do. One day I'll go with Ohlins all around but this will hold me for awhile & for less than $40.00. Bel ray is a good product I'd just try a lighter weight it only takes an hour or so to change the fork oil.
David
Thanks
David
Don't get hung up on brand names or weight value, all fluids in a given weight class are not equal, upper and lower temp viscosity can vary greatly. Search the internet for suspension fluid charts for a real comparison and an idea of what direction to go. Fluid change is decent interim fix but there is no high tech OEM fork valve, changing to heavy fluid may reduce brake dive but it will also affect compression and damping. Not bashing the approach or saying don't do it, just be aware of what your're doing to all functions of the forks.
Bel Ray is one of the oldest names in the motorcycle industry. I've been using the stuff since the late 60's.
I also use 15 wt in the front and it helped with brake dive to be sure. Just keep it at the same level as stock.
If this is the first time the bike has had the fork oil changed out you're in for a big smile the first time you ride it with the new stuff. That stock stuff is horrible. I think it's some kind of salad dressing in Japan that doubles for fork oil in Showa forks.
