Sirius/XM radio
I'm going to utilize the new aux input made for the infotainment systems and have input# 3 setup. My question is how have people mounted they're docks and the antenna for function and fashion. I already own and have subscription on a Onyx. There is not a lot of room on the bars on a 14 FLHTK.
Steve
Steve
Steve
Steve
Is yours the the module that plugs into the infotainment or is it a sirius xm dock system?
That only works if you have cellular reception. Some of the best riding, at least in my area, is in areas with spotty or no cellular coverage.
I use my cell phone and connect Bluetooth with Pandora radio which I like better & NO cost to download Pandora on your phone... works great. No way I'd drop $400 for a module when Pandora is free..
If you buy the module on line from a discount dealer, you can get it for $320. Don't mount the little "Chicklet" sized antenna under the fairing; I tried that & it worked horribly. I moved it to the top of the dash, to the immediate right of the vent & I have excellent reception - I can even listen in the garage. For me it really was the best solution.
I'm assuming that required you to drill a hole in the inner fairing? Got pics?
To get it there, I pulled off the front of the fairing & pulled the antenna off of its metal mount & placed it on the dash where I wanted it. The wire to the antenna is a fairly small diameter & it actually runs under the windshield as it comes up to the top of the dash - actually, the top right side of the vent (opposite side of the open/close button) is where I have it mounted. Since I didn't have a small, round file I took a small diameter drill bit & made rounded, vertical groove in the very front edge of the fairing vent for the wire to lay in, so the windshield would lay flat on top of the wire. This is all hidden when the front of the fairing is in place.
I think I'm making it sound more complicated than it is. It was a simple job, and made a world of difference in the performance of my XM unit. The reception is now on par with that of our SUV, which has a factory roof mounted antenna. Before I moved the antenna, I was ready to cancel the subscription & list the module on EBay because I couldn't stand to listen to it. It would constantly drop the signal; sometimes I would get a message across the screen telling me there was no signal. Now I have a full "3 bars" of reception most of the time.
