KST Kustoms question
Old 02-21-2014, 05:50 PM
JPMathers's Avatar
JPMathers
JPMathers is offline
Default KST Kustoms question
I have 06 EGC and bought 10 3/4 KST mayhams I think I can make throttle/idle cables work, everyone says brake line works although I cant figure out how I've done everything except hook my truck to it and stretch it and the clutch forget about it no way any helpful hints would be appreciated. If I need brake line I'm thinkin +4 also +4 on clutch unless someone has other suggestions. thx Paul and if you know a reasonable place for cables(if such a place exists) that would be great
Old 02-21-2014, 06:51 PM
Mac daddy 103's Avatar
Mac daddy 103
Mac daddy 103 is offline
I don't have any answers for you, but I did go with the same bars & +4 on clutch cable and Namz 4" extensions waiting to be install in about A month as my bike is in storage
Old 02-21-2014, 06:54 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
Don't believe you'll get the stock clutch and brake line to fit on the 10 3/4" bars. They will barely reach on the 10" Twin Peaks. +4 on both should be perfect.
2010 Limited with some stuff
Old 02-21-2014, 06:59 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
for +6 cables on my 14", i ended up with Barnett thru J&P cycle as best price. You may find some on ebay that are brand name in the plus 4 size. they are usually fairly inexpensive. I've seen some new ones go for less than $20 on there.
Old 02-21-2014, 07:07 PM
crimson13's Avatar
crimson13
crimson13 is offline
Plus 4 oughta be right
Old 02-21-2014, 07:28 PM
JPMathers's Avatar
JPMathers
I see magnum shielding says I can order top line and they have descent prices,does brake line come apart at splitter so I can order top ext. only or is it on e piece to calipers
Old 02-21-2014, 07:30 PM
SBates08's Avatar
SBates08
SBates08 is offline
If it is the stock brake line it's 1 piece from top to bottom.
Old 02-21-2014, 07:37 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
There should be a splitter under your triple tree. I have the 14" Mayhem bars and quite fond of them. Magnum Shielding is the way to go. As my bars are black I went with their black pearl as my bars are black. Have used MS cables for years.
Old 02-21-2014, 07:39 PM
SBates08's Avatar
SBates08
SBates08 is offline
Mike my splitter on my 08 was a 1 piece block. I believe the OP's will be too.
Old 02-21-2014, 07:49 PM
JPMathers's Avatar
JPMathers
yea its stock I'll see if I can see any threads on block but I think your right one piece
Quick Reply: KST Kustoms question
