Fuel pump primer ?????
Old 02-22-2014, 02:09 AM
Helrazor's Avatar
Helrazor
Helrazor is offline
Question Fuel pump primer ?????
after i turn on the ignition and wait for the fuel pump to prime, then start the bike it kicks back on and constantly make the humming sound from priming.
has any one ever had this happen, or have an idea what the fix is?
Old 02-22-2014, 04:46 AM
gs34doc's Avatar
gs34doc
gs34doc is offline
Big Kahuna HDF Member
Yep.....Take the fuel cap off and look in the tank while the bike and pump are running. If you see the fuel being churned up in the tank, then you've got a hole rubbed in the internal line from the pump. This is a fairly common thing and there's lots of information here about the problem and the fix. Do a search and you'll get more info than you can possibly use.
Old 07-06-2021, 10:46 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is online now
Spoiler
Be sure to check the throttle plate adjustment screw. It looks like an idle speed screw but it is not. It is used to keep the throttle plate from closing all the way so the bike stays running after a stint on the highway that heats everything up and makes it easier for the throttle plate to seal off outside air at idle.
Check if the screw is loose by taking a pair of needle nosed pliers and try to turn the screw from the backside.
If it moves you got one of the bikes to get out of the factory in 2007 (common issue) without locktite.
Let us know what you find. If loose we can direct you how to reset it and keep it from moving.
Bob
Old 07-06-2021, 12:16 PM
Dseago1969's Avatar
Dseago1969
Dseago1969 is offline
Originally Posted by FLTRI17
Spoiler
Bob
his signature has a 2010 in it.
Old 07-06-2021, 07:24 PM
Rustyg500's Avatar
Rustyg500
Rustyg500 is offline
When you first turn the ignition on the ECM will run the fuel pump for 3 seconds to get fuel pressure up to 55-60? psi then shut off with the pressure remaining.
Once you start the engine the pump will then be activated and run continuously until the ignition is shut off. This is to maintain the 55-60? psi so the injectors can keep a predictable stream of fuel to the combustion chambers. If the psi exceeds the 60psi a regulator valve will open and return excess fuel to the tank.
if you look at your tank you have two hoses, one is the high pressure hose coming from the fuel pump to the fuel rail, the other is merely a open hose for the return of fuel to the tank.
If you can hear the pump over your pipes then you probably have a pump going bad or your hearing is just very acute.
Old 07-06-2021, 08:10 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,356 Likes on 2,613 Posts
Yes, because he likely bought a different bike in the 7 years since he started this thread
Hair53
01-01-2021 02:21 PM
sepperl
07-19-2020 06:21 AM
HoggyMtnBreakdown
08-27-2011 04:34 AM
Coxbow
01-26-2011 11:40 AM
rip
11-28-2008 09:51 PM
Quick Reply: Fuel pump primer ?????
