103 255 cams??
Best bang for the buck, for one forget the HD upgrade, go with a 107 kit & get everything from the same vendor so that it's the right combo of parts. The best parts in the world won't make a good running engine if they aren't used in the right combination. There are several good buiders already listed, Fuel Moto & T-Man have excellent reputations, & they both have geat 107 kits. Where are you located up North? Are you looking to have your HD dealer do the install & that's why you're looking at a HD kit? There are many good buiders in the upper Midwest, New England, & New York, Fuel Moto is just outside of Green Bay WI. The secret to a good running bike is a proven combo by a proven shop, find one that you like or that is close to you & discuss with them your goals & riding style & you'll end up with a winner.
Weard Choises
HI Guys,
Thanks for your advise. Its not a warranty thing, I just have a lot of Harley credits that I have to spend at the dealer, that's what was driving me. Yes I'm doing it myself . After doing some more research I may want to change the cams to woods- 222. The crank run out is 5 THOUSANDS. I don't have a dyno and I would like to avoid that, Besides MY WERD CHOICES is there a better option other than a thunermax tuner. I can pick one up for 699.00 There not $1000.00 bucks anymore. The Dynos around here get $400.00 ??
Thanks in advance.
Thanks in advance.
HI Guys,
Thanks for your advise. Its not a warranty thing, I just have a lot of Harley credits that I have to spend at the dealer, that's what was driving me. Yes I'm doing it myself . After doing some more research I may want to change the cams to woods- 222. The crank run out is 5 degrees. I don't have a dyno and I would like to avoid that, Besides MY WERD CHOICES is there a better option other than a thunermax tuner. I can pick one up for 699.00 There not $1000.00 bucks anymore. The Dynos around here get $400.00 ??
Thanks in advance.
Thanks in advance.
same here. never set a dial indicator for degrees before. I think he meant the high point was at 5 degrees.
I have a 2008 Ultra Classic (FLHTCU) and went with the 103ci SE stage 2 kit when I bought it. It came with SE 255 cams.
I noticed the very poor gas mileage, it always seemed to run hot, and it seemed to run out of torque much above 4000 rpms. It did have very good low end torque
I have since switched to Feuling reaper 475 cams and Thundermax and it runs much better. Went from around 33 mpg (SE-255 with over 30,000 mi) to 39 mpg with the Fuelings, The engine runs cooler according to the oil temp gauge, and I have more power.
just my 2 cts
just my 2 cts
HI Guys,
Thanks in advance.
Thanks in advance.
Here's my input, and take it for whatever it's worth....
I have a 2012 RG, 103". I have stage 1, V&H power dual header, V&H H.O. slipons, TW-222 cams, and a PV. Once tuned to my satisfaction, unlike so many others that boast about huge low end torque gains, my gains are appreciable, but not overly impressive. When racing my buddy (which I very seldom do!) who has a very similar set-up, he stays right with me from 1'st gear though 3'rd. Where I really see my TW-222's show me the difference over his stock cams is about when we hit 4th gear. It's in the mid range that I walk away from him, and my bike is still making amazing power (to me) in 6th gear at 90-105 mph.
Because it's so rare that I ride at those levels (frankly, it scares the **** out of me), that's not where I really wanted my power. I don't know what's different about my set up from others with 222's that boast huge low end torque gains, if not for the High Output slipons which very well may be causing a slight loss at the low end of the torque curve. Pay attention to that variable if you do choose to stay with the TW-222's! It may be that I need a little more back pressure to see the low end gains that others notice in their bikes.
Am I happy? Yes. Did I get exactly what I was looking for? Not fully. I will keep it though. My buddies with 110' motors will not outrun me, not that I care, but it has been duly noted, and for that I am left "satisfied".
I wanted to piggyback on Oldhippie's comments though, and suggest that he might be correct. Ask a LOT of questions after you've defined what you want and where you want your power. If you think you like the TW-222's best based on what you've heard/read, then make sure that your components behind those cams best compliment them; something I could have done better.
Again, I am happy with what I have, and I am going to enjoy it for some time to come, but I did not get the neck snapping low end torque that I expected. So I am lowering my expectations for now!
It appears as if you know bikes and motors, so take my experience for what little it's worth. Good luck to you!
