Compensator on 2014 Street Glide
Old 03-05-2014, 01:07 PM
SunPilot's Avatar
SunPilot
SunPilot is offline
Default Compensator on 2014 Street Glide
Does anyone know the torque value and procedure for the compensator bolt on the 2014 models? I'm doing a chrome inner primary cover install and the value isn't in the instruction sheet that came with the cover.
I am asking here because I ordered a new service manual and it hasn't come in yet...I have a manual from an older Street Glide but I know there is a new bolt in the 2014. Any help is appreciated
Old 03-05-2014, 01:19 PM
twincam47's Avatar
twincam47
twincam47 is offline
The book says T-70 drive.....tighten to 100 ft-lbs. back out 1/2 turn tighten to 175 ft-lbs.
No mention of locktite at all on the compensator. Page 5.7 in the manual.
Old 03-05-2014, 01:25 PM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
Normally, Red Loctite is used here.
Twincam beat me to it...
Old 03-05-2014, 01:49 PM
twincam47's Avatar
twincam47
Yeah they mention it for the clutch hub nut but nothing for the compensator bolt. I wonder if the concern is getting the locktite on the stack up components of the new system or if 175 ft.-lbs. is tightness enough?
Old 03-05-2014, 01:54 PM
SunPilot's Avatar
SunPilot
SunPilot is offline
I think if it isn't mentioned, I will go without the loctite...Harley manuals are usually pretty good in that regard
Thanks a bunch...can't wait to get my new manual...
Old 03-05-2014, 05:15 PM
SunPilot's Avatar
SunPilot
SunPilot is offline
I noticed there is no lock nut on the clutch pack, I assume because of the hydraulic actuator....can you give me the procedure for removing the clutch please. If anyone has the removal instructions and can email them to me I would greatly appreciate it...now that I have the outer cover off I really don't want to reinstall and wait for my service manual to get here. Thanks
Old 03-05-2014, 06:12 PM
BigDawgQC's Avatar
BigDawgQC
BigDawgQC is offline
Not sure about the new one, but when I put the SE Comp in last summer, the bolt had the red loctite already on it.
Old 03-05-2014, 07:40 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
You said you were doing a chrome inner primary " cover" install. You don't have to go into the primary, much less fool with the compensator, simply to install a chrome primary cover.
Old 03-05-2014, 07:49 PM
bullpupp12's Avatar
bullpupp12
bullpupp12 is offline
i think the op is replacing the inner primary with a chrome one
Old 03-05-2014, 07:54 PM
SunPilot's Avatar
SunPilot
SunPilot is offline
Well, apparently I used the wrong word. I am doing a chrome inner primary "housing" install. I realize that to put a simple cover over the existing one does not require tearing apart a big chunk of the engine, transmission assembly.
Quick Reply: Compensator on 2014 Street Glide
