Fuses keep blowing
Fuses keep blowing
I started up my 08 Road King today after being on the battery tender for a few months. However I took notice the turn signals and brake light did not work. I checked the fuses and the accessory and P&A fuse were blown. I change the fuses out, turn the ignition/headlamp switch on and they both blew instantly again. Any idea what the issue could be, there is nothing extra attached to the battery and I made no changes to the bike before putting it away for the winter. Thanks
You've got a short somewhere. I'm guessing somewhere, there is a bare wire making contact with metal on your RK, causing the fuse to pop.
I recently ran into an issue on a bike I helped look over. It was an Ultra Classic, and the front fender tip light wires were damaged because the clips came off the inside of the fender, allowing the wires to rub/chafe on the tire.
It was causing a fuse to pop as well, and if I recall, it was the same one. I can't be certain.
I'd suggest getting the bike on a jack, and looking it over really well with a flashlight. This may be a tough one to isolate.
Good luck, and Semper Fi.
sounds like you have a short circuit...like insulation rubbed off a wire or chewed by mice, and contacting the frame.
disconnect the plug under the seat for all the rear lighting.
if fuse holds, then you have isolated problem to the harness which runs to the rear. ( and for this testing i would suggest replacing the 15 A fuses with lower rating - like 2 A - to reduce any damage to wiring or sparks)
if you have a lowered bike, the tire could have chewed some wires...or road debris...or mickey mouse.
or you could even have a bad bulb.
remove the bulbs from the sockets and try again...if the fuse blows, the wiring is the fault. if not, replace bulbs one at a time with the ign on
try that first.
it is odd that both of those 15 amp fuses would blow at same time as they control different circuits/ loads on the bike...
BTW fuse in which the metal inside looks like it just sagged and melted indicates too much load for that fuse rating
a fuse in which the metal is spattered and maybe shows soot/ carbon from arcing indicates a short circuit.
mike
try that first.
mike
