Front brake line help
Old 03-13-2014, 06:42 PM
dynamic098's Avatar
dynamic098
dynamic098 is offline
Default Front brake line help
I am replacing my front brake line from Abs to the front calipers. I am having a hard time with the attachment below the tree. The oem line has a mounting point that is shaped like a pear with two holes, one for the screw and one for a mounting pin. The new lines from Harley have a round disk where the three lines come together. It also has the two holes. I can't get the new one to line up properly, when I take it back off and line it up with the oem, all of the lines and holes are the same. The new line is the white/chrome lines. Has anyone else had this issue ? I need help.
Old 03-13-2014, 07:29 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Going to need some pics to get a better idea what your asking.
Old 03-16-2014, 04:30 PM
dynamic098's Avatar
dynamic098
Default Pictures
So here are a couple of pictures. With the stock line, the pin under the tree sits in the crook of the connector. The new Harley brake line is a round disk that does not have the crook. What do I do about the pin ? Do I grind it off, do I drill a hole in the disk, or would I shim out the bolt to the height of the pin ?
Thanks for any help...Front brake line help-20140316_165337.jpgFront brake line help-20140316_165353.jpgFront brake line help-20140316_165701.jpg
Old 03-16-2014, 04:33 PM
Boyer8's Avatar
Boyer8
Boyer8 is offline
Default Pin
Cut the pin off. I had to do the same thing.
Old 03-16-2014, 04:51 PM
BCarlin's Avatar
BCarlin
BCarlin is offline
4th Gear
The alignment pin is a roll pin, it didn't align with my new brake line puck either. Pull it out with vise grips.
Old 03-16-2014, 05:14 PM
dynamic098's Avatar
dynamic098
Thanks guys.
ncracer86
Touring Parts
07-01-2017 06:04 AM
InsomniaInc
11-08-2016 10:15 PM
fxhawg85
05-10-2015 06:37 PM
r0de_runr
Engine Mechanical Topics
01-02-2014 08:29 PM
Bryan TTM
02-24-2008 09:29 PM
Quick Reply: Front brake line help
