Air Cleaner Mod
Old 03-13-2014, 08:41 PM
kylebryan's Avatar
kylebryan
kylebryan is offline
Default Air Cleaner Mod
Anyone on here modify the stock backplate on the air cleaner on their bikes for better air flow? All the stage 1 intakes seem to just have a modified backplate and highflow filter. If you have post up some pics.
Old 03-13-2014, 09:41 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
the Evo and TC air cleaner up to 13 can be attacked with a hole saw...drill a bunch of holes in the circumference of the plastic plate.
OUTSIDE the filtered area.
most hi flow air cleaners incorporate a velocity stack, that small air horn makes a huge difference in flow numbers.
so you wouldn;t have that..but you'd have higher than stock flow, and probably about as much air as the motor can demand
mike
Old 03-13-2014, 10:15 PM
Duc's Avatar
Duc
Duc is offline
Build your own or if you want to use stock cover then cut down back like mine in pick. Ran on my 08 like that for years.
https://www.hdforums.com/forum/showp...postcount=1055
Clif
Old 03-13-2014, 10:23 PM
kylebryan's Avatar
kylebryan
Link doesn't work
Old 03-13-2014, 10:30 PM
Duc's Avatar
Duc
Duc is offline
Originally Posted by kylebryan
Link doesn't work
Doing it on my phone so I can't hyperlink it, you'll have to copy and paste the address
Clif
Old 03-13-2014, 10:35 PM
Duc's Avatar
Duc
Duc is offline
Clif
Fixed it
Old 03-13-2014, 10:39 PM
kylebryan's Avatar
kylebryan
Got it! Anyone else done this? Seen any power gains?
Old 03-13-2014, 10:53 PM
Duc's Avatar
Duc
Duc is offline
I have xpipe, gutted muffs (fullsac cores), & filter mod so can't say filter mod is why I have power gain.
I can tell you HD's are lean to begin with so if you start tinkering and I personally think period you need to map\tune bike IMO.
Clif
Old 03-13-2014, 11:02 PM
kylebryan's Avatar
kylebryan
Already bought a PCV. Waiting for the mailman...
swifty
03-31-2017 09:12 PM
Traxxtar
05-06-2015 08:27 PM
Afdharley
Screamin Eagle CVO Models
01-09-2015 10:20 AM
dale44
10-06-2013 03:17 PM
snuffer
04-19-2009 05:17 PM
Quick Reply: Air Cleaner Mod
